Eddie's table modifier
CrazyGuy03
Active member
just to show - its super simple, effective and works so I been using this since 08 and everyone still ****s on it and ****s on maf tuning so im just gonna post the text file to show the changes
i kept the stock maf file for a N* v8 truck given from a member here
I had "decent" trims but i was not getting my MPG that I was used to
one cruise , one file transfer into the program, loaded it back to my ecu and well im locking +/- 2 while cruising now and my MPGs are back into the 30s
edit cant upload a 15kb text file?
edit cant paste the document here without it distorting the data columns Scotty? can u figure it out ?
I guess back when I started , it was this or spreadsheets and math. I learned this way. And for as long as I had the s1x cam - I only tuned my car once.
So getting back into it again , it was just as easy as I remembered.
Now I was getting +16.4 at idle and on de-accel on the thruway. So I wanted to try to get my trims back to normal from idle to about 7k on the maf
who knows if the s3 cam has anything to do with some
of my off readings. I know I need to run around 30* at idle to keep the car from "hunting"
I've used it. It seems to work when the tune is off a good bit like when I used the stock MAF table then used it after logging then it was better then used it a second time and it was a little better, but it seems after the second time it wants to over shoot or under shoot. It's great for getting close the. I just modify the table manually after that.
