eddies table modifier thingy?
lance4682
using this on windows 10 scanning with uvscan2 . i import my scan import my maf table and when i try to export the new maf table it keeps coming up with error ........an unhanded exception has occurred in your application.if you click continue the application will ignore this error and attepmpt to continue....cast from string '''''''to type double not valid........anybody ever encounter this and know what to do next
crap neither worked the one said class registry error when opening. the other installed and when i try to import my scan into table modifier it says 5548 bad lines on scan were not imported.any help....maybe windows 10 is the issue
when it says bad lines you got a bad scan some how. get that crap all the time with eddies tho.
if your using dhp, scan with dhp, export that scan, its as good as uvscan to me, its all i use cause uvscan is full of issues.
i tried scanning with dhp but when i went to disconnect and save the bar that fills up while saving had one block left then froze ..... i just want to 0 my fuel trims ...why god why
mine will hardly ever lock up saving, but when it does, the scan is still in logs.
if you ever played with the settings for the scan that might be why. also make sure your running dhp as admen. try that with uvscan too, cant hurt. just right click the icon and run as admen.
