BLUESMOKEGTP
What is the suggested list of items needed to run e85.
Pump rewires supposedly bump up the same setup (whether you're using a stock or aftermarket pump) by 10+%
I would recommend a rewire no matter if you're staying stock, or going for a big build. It can only help.
I have heard you can get away with a stock pump using a rewire and larger injectors somewhere in the 300-320whp range. Haven't tested that theory yet myself, but I'd believe it.
Just fill'er up and go?If you have 42s you dont need a tune wideband etc... just get a good fuel pump and leave the rest stock. Porting heads is real real hard to do correctly and there are easier gains to be had with a cam swap and or a turbo swap.
I do have other mods also. Lq4 maf n* tb ported sc 9.5:1 comp bottem end. Is it surely safe to run this setup with no tune
