hey everyone been dealing with this problem for a min
around the start of the summer I switched my car from 93 octane to e85 to do the switch I went to #60 injectors, sent a different pcm than the one I've been using on my car to zzp for a tune ,installed a high flow fuel filter, did the fuel pump rewire, and swapped to a lq4 MAF all at once and ever since my car struggles miserably to start (3 or 4 tries minimum) if its been sitting for 10+ hours NO MATTER THE TEMP even in that recent heatwave where I was at temps were at 100F once it finally does start it will run very rough if put into drive and sometimes stall in the first 30 sec after that the car runs amazing in fact best its ever ran. I've heard of cold start issues with e85 but this just doesn't seem right also received this code recently p1626 and wonder if the pcm is to blame. I checked fuel pressure and all the numbers were great even held pressure for over 30 min. changed the fuel filter again. changed the spark plugs. just changed the o2 sensor (upstream not running downstream only wideband). I've been in contact with tim at zzp and plan on making the trip down there and have him take a look but its a 3 hour drive and am trying to plan a trip out there but i would like to try and fix it before going. any suggestions as to what could be wrong im open to anything because i am stooped any help would be appreciated.
car is a 2004 gtp for reference
