Need to replace the orginal struts on my 04 Comp G.
Stick with OEM / AC Delco or what else would you recommend that is currntly available? Do they have a drop in strut for AC Delco or do I need to buy all the components separately and put them together?
Also considering the ZZP Performance Drop in Strut with Lowering Spring (link below).
I realize this will lower it a bit and will need to also buy the shorter dog bones.
I'm okay with lowering a little but not looking to get "slammed".
Anyone else used the ZZP Perforrmance Drop in Strut with Lowering Springs? If so, how did you like it. I've read good things abou the KYB GR2s.
What other drop in struts would you recommend for a Comp G? Not looking for coil overs or going really low.
Performance Drop in Strut/Lowering Spring Combo | ZZPerformance
