DRL to fogs && projectors Lows on with Highs
mikeygan17
(you MUST have a relay in for the lowbeams in order to do this!!!!!!!!!!!!!!!!!!) UNHOOK the BATTERY and the DRL DIODE
DRL FOGS:
cut the tan wire from the DRL diode
connect a wire to the tan wire coming from the diode and run it into the engine bay, find the fog relay in your fuse box nd solder into the #30 post
plug everything back in and hook up the battery
test it out
now you have fog DRL and your fogs still flip on at night
LOW'S ON WITH HIGH'S:
now to get your highs to work with your lows in the projectors:
remember the tan wire you cut from the drl? thats is rerouted back to your lowbeams so your going to take that and make it splice into the photocell that has the power coming out of it on your dash so in night mode they come on and stay on (the lowbeam relay will be reviving power at all times when the car is on and your night mode is on/photocell is covered/darkend)
and now your lowbeams that stay on with highbeams
Disclaimer: although i have done this with great success in 2 of my Grand Prix's, one can do these mods at their own risk, i am not held responsible for any damages of losses
ive tried it on my 97 & 98
i cant recall but i think 98-2002 are basically the same system, i could be wrong though, if someone could verify, that would be great!
and i believe this should work in the 97-02 regardless, now 2003, im not sure as i have never been in one let alone seen the electrical work, i know in 2003 there where many changes and im not sure if the electrical was one of them
i dont know on the 04+ systems as they are completely different
