Driverside power door unlock issue
Reverant GTP
I have a 2004 Comp G with a non working driverside power lock not operating. I bought the car this way so i have no history. I have replaced the motor inside the door that operates this function, thinking it was that. However upon replacement it still does not work. Any ideas? All the other doors work just fine with the key fob or the button. Just the driverside i have to operate manually.
Might be time to open the door panel up and check for power at the harness with a multimeter. May have a broken wire to it somewhere. I also wonder if the master switch is bad if it will prevent the keyfob from unlocking it as well. Never tried before. Just thinking outloud here.
