No surpriseI'm confused.
What if he tested it and then put it together, changes nothing about his issueYou put the door back together without testing it?
Good question on what was the issue, clearly the door won't open from either handle is the current problem.Where were your issues? And what are the issues now?
You just asked thatWhy was the handle replaced?
That's what he saidIt won't open from inside or out?
I'd kinda expect you to post the nice parts diagram showing the likely pin/problem area. C'mon man.. get that diagramThere's a pin that probably came loose just behind your inside handle.
I don't know about Grand Prixs, but I could get to it on my cutlass with the panel intact.
No surprise
You just asked that
