SyntheticShield
How would I go about draining all of the coolant out of the system? Heater core, block, etc. If I wanted every drop out, how does one go about doing so?
remove all hoses intake manifolds, heads too. turn car upside down, let it all run out
lol no really, i'd venture to guess that without either complete disassembly and/or pressurizing with air, you'll not empty the system completely.
well, this is a very easy way to get the coolant out..but then again, you shouldnt do it unless you have a ****ty shop vac that you want to destroy by sucking coolant through the fan bearings and motor.
but i used a shop vac when i was taking everything apart. cleanest ive ever been when i was doing a rebuild.
You know, I remember seeing something to that effect. And I just spent $80 on a new wet/dry Shop-Vac so I am in no hurry to mess it up.
I used a wet dry vac last night on Drew's cooling system. Scotty you are probably right about the water pump. Drew was holding the vac (small craftsman wet/dry) while I hit the LIM/Tstat housing area and bottom opening of the radiator. When I got to the water pump and started to vacuum coolant from there. He and I were both amazed how much coolant was extracted.
Even with all the hoses removed? Did you pull the knock sensor?
What was your process? Were you vacuuming from the Tstat housing and he was doing the same from the water pump? Give me some details, and when I get around to draining mine out I will see what I can come with. I definitely want to build something like Toasty posted though just to spare the poor Shop-Vac.
