Downpipe and rocker installation ???'s
dmahlikGT
Soon I plan on moving to my next mods which will be a downpipe and rockers.It seems like the downpipe is pretty easy but just to make sure all i do for that is raise the car,remove old downpipe/cat/ubend with bolts then just rebolt on the new downpipe? And as far rockers, how involved is that?That seems more like a task.any help?
ahh,thanks man.That defiantely helps and ill be using that guide when im ready.But am I right as far as the downpipe is concerned?Will i need to seal joints or anything?
depends if you got a bolt in or a weld in. The weld in will obviously do just that. The bolt in you will need a new DP to Exhaust gasket. The metal gasket that is at the rear manifold to downpipe can be reused. Or you could just get new for both.
Also...red RTV the piss out of everything...it never hurts on the exhaust side to eliminate any chances of leaks.
