door panels
bb52190
Can someone tell me how to take my door panels off of my 99 grand prix se...i have tried but they are getting stuck is there a hidden screw or bolt somewhere that im missing...i need help...thanks alot...im redoing my interior and need the door panels off...thanks
Please be sure you're posting up in the correct section that way you're question yeilds the best answer.
This section is for Write up's.
Moved to correct section.
There are two screws under the grip of the door panel you need to remove before trying to pop the door panels off. You will see just behind the grip two caps covering the spots where they are located. They are the torx style design, so you will need a set of Torx bits to remove them. And then the rest is a snap.
I hope that helps.
