Door locks unlock & interior Lights by itself
Cobra
Hello, I have a 1999 Grand Prix GT and it has started to unlock itself randomly while I am driving and after car is shut off. Both doors will unlock and the interior lights come on and dim every few minutes when key out of ignition. I have removed fuse from locks saving actuators though still hear relay engaging every 30 seconds or so. Further I have found hitting lock once on key FOB after key out of ignition stops lights from cycling on and off. Please advise after review. Thank you.
Found problem. Upon inspecting wiring near door lock assembly on drivers door. Found wire being pinched by insulation and shorted. Repaired wire. Ding Dong the witch is dead. Problem solved. Hope this helps:)
