Door lights?
chrishova
I have a '97 se and I was taking my door panels off and noticed a little electrical plug near where the "reflector" on the door panel is and noitced the is a place to put a light on the doors. Is there a model # for the harness and bulb socket? A place to find it?
If nothing else I can make one, but the proper plug that fits in the panel hole would be nice.
Thank ya'll!!
I just changed mine out today, they are the 194 bulb. It doesn't look like the type of thing you can make yourself, go to the junkyard.
I go mine from a caddy in the junkyard most all gms will fit just pull open panels until you find one that's what I did
I knew they existed! I could have made up something but I knew they were out there! Thanks for all your help! I guess I should check to see if they are live before I go digging!
pull the panels and start searching, u might have harnes tucked away in the loom , but no reflector or vice versa, happy hunting and good luck
