Doing the exhust myself ?
ryangtp89
Well a number of friends have talked me into putting my exhust system on, now im a little short on cash, soo how difficult would it be to put on my catback system myself ?
If you have a fully assembled cat back that will bolt right up to the down pipe it will be simple (as long as the down pipe bolts come loose). The actual cat back is only held on by rubber donuts and two bolts.
Yes, check to see if it will bolt up first. Then pre-fit everything together to make sure you know it will work and make it easier to fit up when under the car. Use a lot of wd-40 and you might need a torch to heat up the bolts to make sure they come loose.
My damn bolts just broke so I had to grind them off and drill them out and put stainless ones in. Catback is an easy change if you can get the bolts out.
