does anyone no if I can hook a apexi safc up in a 97 grand prix gtp
Why would you not just get HPtuners. SAFC doesnt have a Sensor type listed for the grand prix. Which you need to select or the reading will not be calibrated and engine failure may result apexi safc manual
the safc is out of my tsi talon and i already own therefor if i can use in to increase a little fuel under boost it will serve its purpose. suposibly it will work if i can hook all the corect wires up
youre doing it wrong if you want to drop pulleys already. leave the SAFC alone and read about how these cars work. DO NOT INCREASE BOOST ON A STOCK CAR.
It won't work...you'll just end up popping a piston in the car. If you want to go faster...READ and RESEARCH.
Headers, a 3.4" pulley, a TUNED PCM...not that SAFC junk...that's what you want. This isn't a 4G63T...you can't just use stuff from it.
Ok iv done some reading and a site zzperfornance has a intercooler and they say with it I can run a 3.2 pully with no nock is this true ? If so will a stock engine handle it? Or am I better off just going with a bigger throttle body a 3.4 pully and tuned pcm? And instead of a tuned pcm can't I use the AFC made for gtp or does a tuned pcm do more than add a little more fuel . I already have a air fuel meter .
