does a 3.4 pully require a smaller belt?
00Daytona
I bought the stock replacement one and put it on and the car feels much slower. I figured the tensioner would take up the slack am I wrong? Also its squealing off and on
It requires a larger belt, you have less power and squealing cuz it's slipping because the tensioner isn't pulled back far enough to apply enough pressure
I threw the stock belt back on and had no issues on a 3.4...if you don't have belt slip I wouldn't worry about it but every car is different...the safely modding thread I believe has the size chart
Let us examine this shall we? Pulley is .4" smaller diameter, power is lost, and belt is making noise...
And the question is should I use a smaller belt?
I'll just leave that there...
667 - GTP/GS/SS supercharged with stock 3.8" pulley (67 1/4" -1708mm)
658 - GTP/GS/SS supercharged with 3.2 - 3.5" pulley (66 3/8" - 1687mm)
650 - GTP/GS/SS supercharged with 2.9 - 3.1" pulley
645 - GTP/GS/SS supercharged with 2.6 - 2.8" pulley
716 - Bonneville SSEi with a 3.4" pulley
721 - Bonneville SSEi with stock supercharger pulley (72 5/8" 1845mm)
Taken straight from http://www.grandprixforums.net/threads/67580-Safely-Modding-Your-3800!
