Do you run no IAT sensor?
slimguns
I ask because a reliable source said I could and the ZZP photo of the Z7 kit doesn't appear to have one. Also my install didn't mention it. What do y'all think?
I'd run one.
Its not like its hard to relocate the sensor. Our PCM can use that temp to pulling timing if it thinks the air coming in is too hot, which can help save itself.
the TR's is hanging in front of the radiator behind the grill via extended wires
SI 3800 IAT's are thread in 3/8ths npt so you can weld a bung onto a pipe for a more secure setup.
i wanna put one in each end tank of the IC with a signal switch for some info via the datalogs
my 97 gtp its hanging next to the HAI cone lol
Series 1. Also fieros have threaded sensors.
again I suggest against running one. They are horrible at boost applications because of how slow they are.
In my 97 it was zip tied to the throttle body for a while then I redid my intake and put it in the rubber tube I noticed no difference between the 2. Unless you absolutely want to know what your intake air temp is I would just say leave it off.
