Display/ lighter out?
bmx6454
Hello all, my cd player display and ciggaerette lighter won't work. I can't figure it out. I checked the fuses, but I'm not getting anywhere.. Thanks.
Does the CD player still physically work, just no display? If so then the bulb that backlights the LED display is shot. Common issue. GM has the bulb. If you can't find the part # I can look it up as I've replaced the one in mine before. Maybe pull the cig lighter out and check the leads for power if the fuse checks out good. Might just be a bad socket.
yea, the cd player works. i thought the two were related. and the cig lighter socket is getting no power at all. will check the rest with a tester 2morrow.
