Disable Tire Pressure Monitor Alert?
bocoogto
I use aftermarket wheels on my GXP for winter. They have no sending units for tire pressure. Is there a way to disable the alert so I don't have to reset the readout every time I start the engine? Also, the yellow warning light is always lighted in the cluster with the sending units not communicating with the monitoring system.
Gotta pay to play.
You could save a couple bucks buying through napa online to get the 10% off, would be around $140-145. Shoot maybe even auto zone has better online discounts once you reach over $100.
to avoid buying new sensors, you can pay labor to remove your current sensors, buy std valve stems, pay a welding shop to build a pressurizable box, put your TPMS sensors inside and pressurize it to 35psi and let it roll around in your trunk
should only cost about 200-250$ and youll be able to put any tires/rims on it you want afterwards
