DIC swap
chrissbee77
have a 01 grand prix gt 3.8 non turbo. I want to swap my anolog DIC with a digital DIC from a 01 gtp. I was wondering if someone could walk me through the process thank you this is my first posting on this website.
the first thing you'll want to do is pull out the current one, and check back around in the dash and see if the digital plug is there... it's quite common to have both plugs in the dash... if its not there, i know there's a thread here with a link to the wire harness routings that need to be done.... if i find it, i'll post it up.
Well, the FIRST thing you need to know is that not all model year DICs are interchangeable. 1997 and 2003 are unique to themselves. 1998 thru 2002 will interchange. The 1997 cars require an additional wire be tapped into the instrument cluster header. You can pull a pin from your analog DIC header and insert it into the instrument cluster header in the appropriate position. Below is the wiring diagram for all the years. Note the 97 changes on the right hand side.
So to switch from analog to digital in my 03 do I have no other choice but to use another 03 dic?
I am going to attempt do this swap this weekend. Hopefully I have the other plug behind there....Any more info on the swap would be helpful!
definately no extra plug behind the dash. unless i forgot to check some place. so any info on this routings/wiring harness/retrofit thread?
Hey,
Check out this link, I'm working on the same project only I'm looking at doing the DIC, HUD, CC, Leather and Auto Headlights. Bigs jobs I think but I'm going to pick at them this winter one at a time.
I loved the options in my old 98, it had everything. The problem was that the body started rusting and alot of other issues with it, so I bought a 2001 GT and I'm going to move the options over.
If anyone has any suggestions on these other jobs, please feel free to send me some info.
whoa whoa whoa...i didnt know i could swap my analogue for a digital...how much would this cost to get professionally done?
sorry for asking, but can somebody tell me where I can buy one of these, and what they display??? i dont have tire pressure sensors in my 00' GT...i want to do the swap though
Guys you don't just buy these things new. You can buy them from a scrapyard or do like I did buy the whole car.
A hud can be bought online new but that is all I'm aware of. I don't think that your going to find "professionals" who are going to undertake this stuff, I know I'm going to be on my own with the exception of some help on here.
I think I have a 97 (since the digital has a tire pressure light above the low trac light). What specifically do I have to do to make it work? Where am I suppose to put a new wire into what instrament header, why? Anybody know specifics? I'll give it a try and let you all know how it goes. maybe this explains the flashing zeros.
The extra wire to the instrument cluster is to tap into the fuel feed. The 97 cars did not include the fuel information on the data bus, only at the cluster. Lack of this information will cause the DIC to flash zeros. The diagram shows where to tap the cluster. Take an unused pin out of your OLD DIC connector. You can use this pin to insert it into the cluster header, and tie it into an extension wire over to your new digital DIC.
No 07-03 GPs have tire pressure sensors. The ABS computer checks the relationship of all the tires rotational speeds to each other and if one or more do not compare, it illuminates the check tires lamp. I think this is a 97 only feature. My 97 had this, my 00 does not.
Thank you for confirming that. What diagram shows where to tap into the cluster for the fuel feed? Or which wire/color/number/empty slot from the cluster do I need to put into which slot in the digital plug?
Now if I get that done, there is only one more question I have and hopefully the thing works. I have one wire left over from my old analog. It is the grey wire for the change oil soon light. Do I not need to connect this wire? Thank you guys.
cboth do you have an 03 digital dic? If you do I want it, Ive been looking for an 03 one for quite a while.
yes i do, got it from the scrapyard yesterday. its in good condition, but i want to know if i can hook it into my 2000 gt first
