DIC Problems
mgrafstein
I did the Analog to Digital DIC conversion in my 2001 GP. It functioned for a bit, now the display is blank. I checked the fuses and bulbs and all are in working order. Suggestions?
pics of the dic and wiring?
you sure you hook everything up correctly, soldered and not used cheap connectors? and if you did, heat shrink or electrical tape the **** out of it?
im doing the same conversion to my 99 right now and im stuck on a few extra wires with no where to put them,oh yea also my car has the right trac control button or unit. behind the speedo im hooked up good and also the information wire by your knees at the bottom.my problem is they say behind the hvac theres a 12 pin connector to splice into ,its not there so where do i place the battery wire and the aux wire,stumped if you can call that would be great,rob 803 420 7770 frustrated thanx
