dhp tuning 1998 to 2001
fbm
Hey guys i have a 1998 gtp bin file that has more calibration options than my 2001 can i upload the 1998 bin to my 2001car
the mafs not the same, and the rear o2 dont work the same.
if you open the two bins side by side, then im sure you could copy most of it over. like click and drag parts to the 01 bin file.
pretty sure he means copying the deleted codes part of the bin file. you'll have to go and delete any codes manually in the bin your copying to.
My trans has been rebuilt at a local shop and it has larger feed. Holes for 2nd and 3rd shifts normal driving with dhp 1.5 shift pressure file and a intense shift kit with performance shift on the shifts are soft but very fast even with stock shift times and i hate it can i go higher with the shift pressure without damage or will the 98 file have the options for firmer shifts i noticed that the shifts are firm onely for a little while till the pcm learns the shift so would the shift quality file on off be the first place try i am saving up for a tep trans for the future but for now i want to. Get the most out of this trans before i replace it
the trans file will copy over just fine.
you have a copy of the trans file that Billboost has passed around? i have shift kit and the trans tune and i dont even use perf shift any more cause it shifts so nice in normal mode.
