DHP tuner?
David99GTP
Anyone knows who sells a dhp tuner? I thought PFYC had them but I did a search function and just the pcm was found
I belive they were discontinued. You will only be able to find on if you buy it from someone used.
For the love of God, if you are buying a tuner, do yourself a favor and get a HP Tuner unless you get a smokin deal on a PT.
I'm a PT owner, and while my product works, the support is now non-existant as well as any software updates/firmware updates/etcetcetc.
There are plenty of people who have the capability to write tuning software for use with the AVT Hardware - but cannot and will not due to a NDA that Charles had them sign.
All I can do is sit here and hope somebody says **** it, and releases software that will at least be updated.
I have a DHP PCM. I can only tune that with a DHP tuner correct?
I don't think you can with anything. It's locked.
FWIW, I only went with PT because I got one for like $200. Not a bad price considering it works. Everyone is crying about updates... it's not like it just stops working one day. It'll do everything it does today for as long as the hardware lasts. There's not a whole lot more that could've been added.
On the other side of the issue, I also hope someone tells Charles to **** off because it's absolutely stupid not releasing the source at this point.
Maybe I'm thinking of intense, but I thought the DHP 1.0 PCMs were locked. The only reason the 1.5 file exists is because its unlocked for PT users to play with, otherwise its pretty much the same as 1.0.
