Devilsown Stage 2 Progressive Alcohol Injection Install...
Iron Indian
Hey Guys,
I haven't been on much lately, been working mostly 16 hour days which leaves me pretty much worn out. I had a little bit of time on Saturday and Sunday to get my Devilsown Stage 2 Progressive 3800 Alky Kit installed on my 1999 GTP. Here are my pics...
Bumper removed ready to get started...
Theres my washer tank, time for some modifications...
Nice flat indention, perfect for a fitting...
Scoring a mark/bit guide...
Drilling the hole...
Flushing out the shavings with distilled water...
Tapping threads into the tank using an 1/8"-27 NPT tap...
Re: hkjljlkkln
Flushing out the shavings once more...
Testing the new threads I made...
Fitting and washer with rubber seal I'll be installing...
Fittings with some thread sealer and grey RTV which will be used...
Fitting, washer, rubber seal put together and thread sealer applied...
A little RTV applied on the washer tank itself, overkill I know, but way not use it too?
Installing prepped fitting...
Fitting tightened and ready to go! Note, Elbow swivels too.
Now its time to run some tubing...
Starting from the drivers side, i'm running the tubing through the bumper support, going to the passenger side...
Re: hkjljlkkln
There it is...
Connected to the washer tank! Be sure to leave plenty of excess tubing, keep in mind, you have some fog light buckets to clear once the cover is back on...
Now its time to mount the pump and run the tubing to and from it...
Here's where I plan to mount it, score some marks and drill some pilot holes. The kit comes with self tapping sheet metal screws, but I always prefer drilling a pilot to make the screw go in easier. Its up to you...
Installing the pump to its new home...
Mounted and ready to roll...
Fittings for the pump, I used a little bit of thread sealer before installing. BECAREFUL TO NOT OVERTIGHTEN THE
FITTINGS INTO THE PUMP, THE BODY IS PLASTIC!!! Note, Elbow swivels too.
Fittings installed and ready to go, i'll wire it up later...
Heres my prerun tubing, time to run it to the pump, make sure to pay attention to which way the flow arrows are
marked on the pump. Be sure to leave excess tubing when mounting the inlet tube.
Re: hkjljlkkln
Time to run some tubing out of the fenderwell and into the engine bay...
Now its time to tap a nozzle into the motor. Luckily for me, I already have a TB spacer perfect for this job.
Bewarned, with my setup it was quite difficult to figure out a GOOD place to mount the nozzle. It took me quite
awhile looking at it to figure out my best route away from heat and moving linkages...
TB spacer off the car and on the work bench...
Time for some drilling...
Then my handy 1/8"-27 NPT Tap...
Mocked up DO5 nozzle and 90 degree elbow...
Re: hkjljlkkln
After several test fits on the S/C with the TB in place I found the perfect angle to mount the nozzle, elbow, and
check valve. I used thread sealer on all the connections, just to be on the safe side. It certainly doesn't hurt a
thing. It enters right below the TPS sensor, you'll see...
TB spacer and TB reinstalled with gasket matched OEM Gaskets with a little bit of Grey RTV to help sealing.
Re: hkjljlkkln
Now its time to figure out where to place the main control unit for the Devilsown kit. My plan from the begining
was to mount it in the mini cubby by the headlight switch. I already have a couple of switches mounted, why not a
control unit too? It should fit perfect. Here it is removed before modification...
Drilled a hole in the cubby so the control units' wiring can run through...
Mocking up the control unit in its new home...
Now its time for some wiring, first we'll start running the wires, control unit, and modified cubby in to the dash
of the car...
After running it under the dash and nicely looming and seprating wires, I wired in the supplied 10 AMP fuse holder
on the red wire power side and I tapped it into a switched 12V source. Since my Acc Power Drop is pretty much used
up and on the other side of the dash, I used my Autometer Volts gauge power wire as a tapping point and spliced
there. I took the black ground wire crimped on a ring terminal and used an existing bolt for the steering column
mount. I proceeded to run the blue and green wires (longest wires in the bundle) to the passenger side wire
gromment and ran the out into the engine like i've done many times before. After successfully getting the wires
into the engine bay, I loomed them up and started routing the wires to there new homes. The Green wire goes to the
MAP sensor and taps into the middle green wire (B) on the connector. The blue wire goes directly to the pump and
wires into the Red power wire. Posi tap was used for the MAP signal wire connection, a butt connector with heat
shrink was used on on the blue/red pump connection. For the pumps' ground I used a ring terminal and some shrink
wrap to seal it off. Drilled a small hole and shot in a sheet metal screw on the frame rail beside the pump.
Re: hkjljlkkln
Added loom to areas that may rub or get effected years down the road. I love loom, can't live without it! I loom
damn near everything. Devilsown Alky kit completely installed and ready to roll...
Re: hkjljlkkln
All I got left to do is reassemble the front bumper/headlights, reinstall my STB, fill the system with fluid (once I figure out/decide what to run), gap my plugs down to .045, and figure out how to tune it. With my work schedule, that won't most likely happen until this coming weekend though. So it looks like the Trailblazer will be my driver this week.
Hopefully my crappy pictures (yeah I know, i'm not a camera man) and brief descriptions help someone out who want to go this route on there GP. Took alot of time and work to get it all on this forum. Hope you guys enjoy this thread...
Wanna sell me that scan master Shawn? How much did ya pick it up for or did ya buy it new?
so youre running completely electrical from the MAP and MAF? i havent really looked at my stuff that much since it's cold as hell and i dont want to work in the cold, but i thought there was a port for a vacuum source too? would that not be easier than running off the MAP?
i dont follow what you meant by that? i thought the controller only gets tapped into the MAP? does the new kit also reads and tap into the MAF as well?
im not sure. i havent looked at it in a while since i havent really been trying to install it in the cold. i know there is an electrical connection to the MAP, but is there anything else? i thought there was a vacuum line as well? maybe a MAF connection too?
o ok, so u werent certain. i have the controller and theres only 3 wires: ground, switched 12v and the wire thats tapped to the map sensor, thats it.
edit-other competitors like snow performance, IIRC, use the MAF sensor as a base of how much to spray the flow, but they're very pricey
Good work Shawn! The install is pretty straight forward, and it's fairly easy if you take your time. The biggest PITA for me was wiring the controller, and making it go through it's diagnostic mode so that I could get it to work.
Thanks for the compliments guys! I appreciate it!
The Devilsown kit I have uses the MAP only as reference for the Alky system, nothing else. Otherwise its pretty much self contained. I touched on the wiring subject above, Here it is...
After running it under the dash and nicely looming and seprating wires, I wired in the supplied 10 AMP fuse holder on the red wire power side and I tapped it into a switched 12V source. Since my Acc Power Drop is pretty much used up and on the other side of the dash, I used my Autometer Volts gauge power wire as a tapping point and spliced there. I took the black ground wire crimped on a ring terminal and used an existing bolt for the steering column mount. I proceeded to run the blue and green wires (longest wires in the bundle) to the passenger side wire gromment and ran the out into the engine like i've done many times before. After successfully getting the wires into the engine bay, I loomed them up and started routing the wires to there new homes. The Green wire goes to the MAP sensor and taps into the middle green wire (B) on the connector. The blue wire goes directly to the pump and wires into the Red power wire. Posi tap was used for the MAP signal wire connection, a butt connector with heat shrink was used on on the blue/red pump connection. For the pumps' ground I used a ring terminal and some shrink wrap to seal it off. Drilled a small hole and shot in a sheet metal screw on the frame rail beside the pump.
Thats all the wiring needed. No vacuum lines are used either, its all electric.
Reptile,
Can you tell me more about this diagnostic mode thing? I don't think I read anything about this in the instruction manual, but its been several days since I looked at it too so I maybe way off. What do I need to basically do? Tips or tricks? Thanks!
