    TIPS:
Delete
Re: GXP Navigation, Comp G sway bar and more
Maybe a dumb question. But...
Would you sell just the rotors for the fbody's?
What do you think shipping would be. It might be cheaper for me to buy new is why i ask
Sent from my VS990 using Tapatalk
I will have to check tomorrow I can get back with you on that. What is the zip code?
im guessing around $20.00 to $30.00 maybe
Think i'll hold off on the rotors bud. I can buy new by the time I pay for shipping. Thanks for offering to split though.
Question though.
Do the ZZP Plug Wire boots bend like the MSD wires do for clearance?
Yes, they will work with with the L32 but not with NA 3.8s
I sent you a message
No, they don't but I never had issues with clearances on my Regal.
actually l67 covers fit na fine.....just not other way around
What drop at the springs front / rear ?
According to 3800 performance:
- Grand Prix Lowering Specs: lowers front approximately 1.3”, lowers rear approximately 1.0”
- Regal Lowering Specs: lowers front approximately 1.4”, lowers rear approximately 1.3”.
- Monte Carlo (2000-current) Lowering Specs: lowers front approximately 1.3”, lowers rear approximately 1.0”.
- Monte Carlo (1995-99) Lowering Specs: lowers front approximately 1.3”, lowers rear approximately 1.3”.
- Impala Lowering Specs: lowers front approximately 1.4”, lowers rear approximately 1.7”.
http://www.3800performance.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=EIBACHS
IS the 2004 Monsoon amp any different thatn the amp in a 2003 Bose system? If it is better, is it a direct replacement?
Can the Nav system be fitted into a 2003, if you disregard the fact it is double din?
I'm not sure if there is a difference.
with enough patience and knowledge, anything can be done.
I only used this on my 06.
