Most likley a vacuume line somehere, under hood, around battery/ in wiring harness or under air box cracked. Or vacuum line under dash pinched.
Are any of the modes switching? a/c vents and floor heater?
I will assume you only have temperature control, no mode controll whatsoever.
My 98 gtp didn't seem to have the vacuume reservoir, but the line by the battery was very fragile with a few cracks. I ended up making a replacement vacuume line out of 1/8" id brake line, routed beside the transmission select cable in the firewall, reducing the length of the vacuume line by at least 1/2. Use the tubing connectors that were on the stock line, and wrap the brake line in the corrugated plastic loom for concealment (this was on the old line, reuse it.)
