DDMTuning HIDs? Quick Question before ordering
karnage
Hey everyone, I am new to this forum and picked up an 04 GTP Comp-G. I had an HID kit from DDM in my previous car ( 2001 S/C Z24 ) and I would like to do the same with this car. I had the 55w Raptor 6000k HIDs ( 9007 ). I am looking at getting the same setup again, except with 9006 for the GP's low beams. I have done some research on here, and couldnt find anything about which specific kit from DDM and which accessories if any needed to be ordered along side it.
I just wanted to verify that this was the proper kit that people are running ( looking at other posts it seems to be ) and see if I needed the error code elim., HID Harness, Adaptors or anything like that to run them so I can order everything I need at once.
Also, in the other car, I had to disable the DRLs to get them to work properly. Will there be any issues that would cause it not to work even if I order the right kit and wire it in properly that I should know about?
Lastly, I may eventually order some yellow HIDs for the fogs, I am reading they are the 880 kit, is there anything else that would need to be ordered with this kit as well to ensure compatibility?
I have already done a double din head unit install, 4 channel and mono amp installs in the car, and I am familiar with the basic wiring. I just want to make sure I have the right parts. Thanks in advance and I am really looking forward to being involved in this community as well.
Your current kit will work, just get 9006 bulbs for your car.
You don't need any of the extra things that are offered. HID harness is optional, but not needed to run them.
Your DRL's on your 04 are you parking lights/turn signals. So, you won't need to disable DRL's on your car.
880 is the kit you need for fog lights and all that is needed is ballasts and bulbs.
Wow, that was fast. Thanks a lot for the info. I will go ahead and order the kit then. I will get a new kit as I still have the other car and I am keeping the HIDs in them as well. Thanks again!
