DDM HID Hookup Help
GrandPrixMI
I just received my DDM Tuning HID Kit, it's a 9007 HiLo 6000K. And I am totally stumped on how to install these. There are so many wires, and I don't want to go and mess with things, so I don't know what to do. If anybody knows what I need to do, please let me know. I bought a relay harness just in case, and if I don't use it I don't care. Here is the picture:
The light should connect to the ballasts in a plug and play manner, you shouldn't even be able to mess them up only one way they fit together and the other half connects to the connector of the original bulbs that were in the car. Then find a good place to put the ballasts so they don't slide around or are in the way. I put mine under the headlights to the inside almost behind the grills. Also I would recommend putting some like spark plug or battery dielectric grease on them before you connect all the stuff because mine have gotten wet and they rusted. I had to take them apart and clean them and then put the dielectric grease on and it hasn't happened again. Hope this helps!
Thanks,
Points70
Well I have a relay harness that came with it, and It has a ground wire coming off of it and a positive wire I have to hook up to my battery. Or that's what my friends dad said who is an electrical engineer.
Only one side of the factory harness plugs are used with a relay harness.
This might help. I am not hip on the 97-03s so if nothing else it'll get you started on your googles.
Welp crap i had some issues with some ddm hid's on the gf car last fall, but hers is an 05, so this didnt really help, lol.
robk
Lol, thanks for that revised image spazzz. I have already gotten the zzp relay harness before I seen this post, but just haven't had a chance to install it yet. But I will definitely refer back to this pic for reference if needed!!
robk
