Cylinder 3 misfire when SC would kick in
Status
Not open for further replies.
Beelzeboul
so my idle vacuum and ltfts are all back in order after my header installation but im having an issue getting a misfire and ses code for it anytime I open the throttle up enough that the supercharger would kick on
was told its probably just a tuning issue with the flo mods I added was also told 3 and 5 tend to run the leanest so if I'm running lean thats where the problem would normally present itself .
Just wanted to see if any damage could occur driving it before getting it tuned so long as im easy on the gas ?
and to confirm its most likely a tuning problem caused by either the massive flow increase or the colder plugs
mods to date
t-stat 180 , SD headers , EGR delete , Cat+resonator Delete , Intake , tr6 ngk Plugs(-1heat range)
Status
