Bogartthegod
Hey y'all I'm getting a flashing check engine light after doing a coolant flush and I can't figure out why this would be happening? Just got this car, 04 gtp comp g with 148k miles and the coolant was very dirty so I flushed good with a hose, did an oil change and supercharger oil change while at it, along with 180tstat and took for a small drive and when I got a over like 50mph I started getting the flashing check engine so hooked the scanner up and came back as a cylinder 1 misfire...any ideas as what could have caused this? I did spill alot of coolant while trying to burp my system and also dumped a bucket of water around the radiator fill which might have drenched part of my coil pack/cylinder 1 spark plug...could this have caused the misfire somehow?? Where should I start?
