whodat79
Ok so i've been trying to figure out why my spits and spudder under load (about half throttle or when i kick in the boost)! lol Ne way it's been almost 2 weeks after mods, hoping that the pcm will work itself out and relearn. The first time this happened it was a random cylinder misfire. so i check all the spark plug lead and plugs. The lead are with in spec of msd. so i cleared the code to see that worked. It didn't... still the same thing. i could still feel it and yet it wasn't triping any codes till a couple of days latter. When that code came up it was now a cylinder one misfire. There for i check the wires again and bought a new plug. I had also had to replace most of the vacuum lines as the broke when dismantling the engine. so i check to make sure that i had then in right. Next i took the injector of to see if it was dirty or what not. there was a lot of oil around the tops of all the injectors on the front bank...Hence UIM and LIM replacement. I reinstalled the injectors and i ran seafoam threw the lines. cleared the code and now i'm back to random cylinder misfire! I'm not ASE certified and i have done all the work myself. but i was very careful on making sure that i had installed the springs and rockers right and torque to spec. HELP PLEASE
