Dtrick22
Today I had my car up on the lift getting some exhaust work done...I noticed that the passenger side CV boot is starting to leak onto my rim..For the past month or so I have noticed a grinding that I can feel through the steering wheel and pedals when turning.(Wheel bearings were done in June).. I also notice a clunk when I shift out of park, this clunk being only when the car is cold...From the same right side I hear a chirp/squeak at low speeds. Could this ALL be related directly to the bad CV?
I am nearly positive that the squeak is not the brakes. I did those a few months ago.
Since I am going to have to order a CV, is this a difficult thing to replace? I have a friend that will do it for $40 (can't beat that) but I am pretty good with cars. This is something I have never had to do before. About how long should I expect it to take ( I have access to air tools..and if I really needed a lift I can use one) If its more of a pain than to just pay the $40 then I won't bother, some things are just not worth the aggravation, maybe this is one of them?
From what I've heard just remove the brakes, disconnect the 2 strut bolts, remove axle nut, then just go right to removing the CV? Or do the tie rods and control arm have to be disconnected for more room..
Is there anything else anybody recommends I should replace while I have things out?
Thanks
Thanks
