CV joint/Axle Question??
Alix0r
Well it looks like my right CV joint seams to be squeaking while i turn and getting worse every day so its time to change them out what do you all recommend as far as axles go? Should i just buy HD ones or stage 2 axles from ZZP?
CV joints and axles time?
Nope get Napas or oem.
Don't fall for ZZP gimmick they fail just as fast from what I hear
Re: CV joints and axles time?
Ya i wasnt going to buy their "Stage 1" axles i would buy them from NAPA but was wondering if the stage 2 were worth it and also if the WBS ones were better then the NAPA ones
Hmm $550 for stage 2 ^_^. I would still get them Napa why because if you have a issue they're right there and come with some type of warranty.. I'm sure wbs doesn't. Can't comment on their quality though but things like that I rather buy locally in case there is a issue. Spend your money elsewhere.
Ya makes since.. i think WBS has a 1year warrenty..but like you said if Napa does then i might as well buy them from there.. it would be easier to return them
Yup and axles are like hubs on our cars you will eventually have to replace them lol easier to keep things local
Get the best warranty local on a rebuilt OEM axle. The new ones (china) are cheap and have been none to snap in half.
I personally bought a used one from Morad.
I put rebuilt ones in mine. Limited lifetime warranty. $81 for both of course mine is just for driving I don't race or anything. Then rebuild the ones you take out. Easy to do I did mine myself and all this crap is new to me.
My passenger side is also making noise I believe. Its been slinging grease under the hood for a while. I almost wanna say hub bearing but the noise is a little different. At 125k miles its probably my axle right?
Does it make a noise while going straight? If so then its prob the wheel bearing especially if its a grinding noise... but if it makes a noise while turning then will most likely be the CV joint on the axle
^^If it is slinging grease then it's gonna be the axle and like said above depends on when its making noise.
Oh didnt see ths slinging grease thing lol... ya its time for new axles like mine :th_winking:
Both axles on my car slang grease everywhere. With gobs of it on the subframe. Had no issues with them yet *crossesfingers* when my wheel bearing went bad it made noise when I turned on like s curves
Sent from my HTC Thunderbolt using Tapatalk
Well in my experience a bad hub bearing will make noise going straight and get louder when u turn. One way being louder than the other. This makes noise going straight and in both directions lol r these things worth rebuilding?
Hey quick question. . So I ordered my axles from Orielys and got the GTP passenger side one.. I remember reading somewhere that the splines might be different from the GT? Will I be able to use these or will I have to end up buying the whole HD diff for the install?
As far as I know the splines should be the same, and iirc the only difference is the gtp passenger side axle is shorter than the gt.
Hmm so it being shorter will that create a problem lol how much shorter are we talking here?
