Mirraco
One BadAzz GT Dawgg
Easiest way to replace cc axle? My driver side has a boot that's torn so I'm going to relace whole thing. I have the outer tie rod off the inner tie rod. What's easiest way to do it? Remove caliper, Hub then get new one in?
is the inner tie rod a lot to replace? Since I already have the outer off of it if it's easy enough I'll do that aswell.
do I have to compress a quick struts spring to fit it on the car? It seemed like where it bolts in is about a inch higher than the one that was on the car.
