Creaky noises...
SDGTP99
Ok so I'm hearing creaky noises from under the hood when I turn the steering wheel. I'm thinking CV joints but im not 100% sure. Nothing vibrates or shakes when im driving so I assume one or both cv joints bad. The creaky noise it all I get
Throw a jack under it and get both front tires off the ground. Fire it up and then turn the wheel lock to lock and see if you hear the squeak. Might also help if someone does it for you while you have yourself down under the car to try and pinpoint the sound.
This is true, but then you have at least narrowed it down some. Right now it could be the rack, a ball joint (or 2), strut mount, etc...
