Hello all, first time posting here. I used to be on clubgp back in "the day" then took a long break from owning a GP.
So here's my question for everyone. What should my CKPS counts be during normal highway driving?
I'm using the Topscan Topdon bi-directional scanner to check out live data while driving due to a check engine light with no code.
I noticed while doing a data stream for the ignition that the 2 numbers for the crank position sensor were red and way out of range.
Doesn't start up so easily when cold, has never stalled out while driving, Light throttle acceleration feels off like it wants to missfire but no missfires are detected, Check engine light comes on at initial morning start up with no codes.
Image is taken during a scan while cruising at 65mph. Thanks in advance
