Cracked Radiator
the955iman
My radiator on my 98 Grand Prix GTP is cracked. The plastic is cracked just below the neck where the upper hose runs back into it. Is there a fix for this or am I screwed and gonna need a new one? Thanks in advance.
Hi, billy mays here for mighty putty! Does your radiator leak? Do you hate putting a drain plug back in after an oil change, can't stand to have your tire repaired after you run over a bolt, try mighty putty *****!
