'04 GP with 259k on it. So i had to replace one of the transmission line bungs on the radiator it was the lower bung. I replaced the lower radiator hose and in doing so tweaked the bung because it started leaking there right after the hose install. Bung went in fine and it looked like I stopped the leak. I have what appears to be a residual leak or maybe a cracked radiator.
Is it common for the radiator to crack at the prongs which insert into the rubber bushings? That's where it looks like I have a leak as I'm not sure if it's just residual or a leak from the crack at the prong. I imagine it might be the prong due to hardened older rubber bushings with age and the miles I put on it. Seems like that's my issue but wanted to get a consensus here.
