Crack pop clunk
Green97GTP
Ok so for the past few months I noticed a loose feeling when putting my car down in 1st driving like 25 mph. It would make a clunk noise. Or if I had it in first driving 25 mph and gave it gas you could hear the clunk. Not it got where any time you stop go turn or break you could hear a creaking and popping.
So last night I changed the motor mount. And as it did make the car feel more tight and not so much getting rid of the noise. What should I check?
Did you check the trans mount?
Although you mention some grinding etc. When was the last time you did a trans service? That would tell you via metal if it was in or out of the trans.
I'm kinda speculating a diff.
everything is up to date car has 270,000 miles and it did not get here by lack of service lol. It was a damn sub frame bolt.. wasn't tight Enough. but was tight Thanks though!
LOL, I wasn't questioning your servicing. Only asking when the last service was. If you did a trans service recently, then I would have wondered if there was excessive metal.
Cool find on the subframe bolt. Odd as well though. Has it been out for any reason?
