Cooling system help
Per Scotty-
open the rad cap (while car is cold), start engine and let the car idle till the fans come on, then open the bleeder screw till a solid stream of coolant comes out. then shut the screw, top off the rad,and cap it.
if your having a heat problem, take the hoses for the core off the engine and flush/fill the core. bleeding the engine wont help get the heat back.​
If you have air trapped and can't seem to get it out. Remove the two 10mm bolts on the thermostat housing and pull the thermostat. Fill right into the lower intake, then replace stat and housing.
My heat works I just replaced water pump and elbows they went out on me on my way home so coolant went every where
Sent from my SM-G900P using Tapatalk
That funnel is awesome, but there was that one time it went flying and took out the bulbs on the ceiling. Be careful when working with hot fluids.
I have my way but maybe there's a right way to do it.
