cooling fans
polarisdescent
i just did a head and both intake gaskets, i no its not common that they go out. my cooling fans wont come on and they work before i started doing the gaskets. i replaced the temp sensor and still nothing, had a friend come over with his computer and try to remote start it and it worked so the relays are good. any ideas what else could be wrong? thanks
Seems kinda odd that they dont come on with the AC.
But here is a picture of the fan settings.
when i turn the a/c on they dont come on
My next question is:
Does your AC work? If the system is interlocked by the pressure switch the fans will not come on.
Fordman77
His buddy was able to command the fans remotely so the fuses/relays should be good.
Keep in mind the screen shot from FFDP is a 2007. I have seen earlier models with slightly higher low speed fan settings.
And...definately odd on the AC. Any codes popping up? Maybe the AC request is being overridded like Rico mentioned
Its not my car though lol, I was just showing the fan settings of a stock 2002 car.
Its always disabled it looks like. The OP has to figure out why his fans arent working.
