digitaloutsider
I'm really pulling my hair out over this issue. I cannot figure it out. No matter what, the both cooling fans start and run at full speed a few seconds after the car is started. They never turn off. Doesn't matter if HVAC is on or off. The fans do not turn on unless the engine is running.
There's no hackery in the car, no jumpered relays, nothing like that.
I searched around some, and someone suggested the Coolant Temp Sensor, but I don't see any odd readings or behavior, it all appears to be functioning correctly. The fan temps in the tune are correct.
Any other ideas anyone can think of? Pretty sure this was happening with a different PCM as well, it's been happening for some time now.
Strangely enough the coolant key off feature works perfectly per the temperature set in the tune.
