Cooling Fan control
schmuve
I have a 97 pont grand prix se 3.8 non supercharged. My problem that i am having is my cooling fans will not kick on. Turn on the A/C still will not kick of course a/c is not workin in the vehicle anyways but that is another day. So I have checked the engine wire harness at the relays, the pcm I check continuity from pcm to wire harnes at relays that is good, ( talking about the the green and blue wire). Replaced the relays, checked wire from wire harness to fans, good. Flushed cooling system replaced thermostat and Coolant Temp Sensor. Still no fans, I have not hooked to a tuner, no real access to one. I jump the relay the fans come on, low and high speed. So I bought a Cooling Fan Control aftermarket to wire in to my fan then start car to set at a temp. I dont know how to hook it up. This is what i need help with.
