Slick2500
Active member
The Cooler Master Stacker 830 SE is a full tower case compatible with E-ATX, ATX and m-ATX motherboards and is made almost entirely of thick aluminum and not cheep secc steel like most cases. This is a big case, standing on the floor the top of the case comes up to my knees, and I'm 6'1" so you should probably have a lot of space either on top of your desk or under it.
If you're an enthusiast computer user who's into cooling, you're going to absolutely love the Cooler Master Stacker 830 SE. The case comes with two 120mm fans pre-installed (one exhaust, one intake) and get this, it has space for another seven 120mm fans! Think of the airflow! Your Crossfire'd or SLI'd videocards definitely won't have a heat problem with this bad boy. Let's not forget that the case is also watercooling capable. The side fan cage holds four 120mm fans in place and swings open like a door. If you're not going to be using fans, you can remove the whole cage.
The exterior features an all black brushed aluminum finish, aluminum front door, tool less side panels 4 front USB 2.0 ports, 1 IEEE 1394 port, and a microphone and headphone jack.
The case comes with 1 4-in-3 device module cage that can accommodate 4 3.5" hard drives, additional 4-in-3 device module cages can be purchased from Newegg for $23.99 with free shipping if you have more than 4 hard drives. I will be including a Bytec 3.5" to dual 2.5" hard drive adapter perfect for 2 SSDs.
Front door of the case is reversible so you can place the case on your left or right whichever is more convenient for you.
The case also includes 4 wheels for better mobility, one of the tabs for the wheel locks is broken, but you can still lock and unlock the wheel. Wheels are currently attached but can be removed via 4 Phillips head screws.
The case is almost completely tool less, only the motherboard, power supply and hard drives are held in via screws.
Case does have a few slight scratches here and there as seen in pictures.
I will include all of the accessories that I could find that came with the case, 5.25" drive locks, top mount hard drive cage, 4 blue led lights, spare 5.25" drive cover and a random bag of case screws.
Looking to get $100 obo +shipping.
http://rap.midco.net/harryjob1/pics/Stacker%20830/20140918_202934.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_203025.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_203141.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_203155.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_203224.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_203241.jpg
http://rap.midco.net/harryjob1/pics/Stacker 830/20140918_202003.jpg
