Coolant spray/leak. Quick fix just 1 question
VejGTP
This is for a 2004 GP GTP. Lately I've been smelling antifreeze while I'm driving, I looked under the hood and there is antifreeze sprayed all over pretty much everything on the left side.
I just had a closer look today and I found out that the small tube with coolant running through it was touching the supercharger belt and it was cut open. The place I bought the car from replaced the battery right before I drove off with it so they must have moved the tube over and not put it back in place. (It is zip tied to something)
I'm just wondering if anyone knows what this small tube is called so I can replace it. Here are a few pictures!
If anyone can help I'd really appreciate it!!
Just go to a parts store with the hose and get some hose the same size. It is supposed to clip into your fuse panel. I just zip tired mine up to the fender brace.
It's been in the garage all day and it's freezing outsize so the car isn't warmed up at all. I started it like 15 minutes ago but only for about 5 minutes.
Thanks for the help :). Got it fixed. Just bought some new hose and used those metal screw clamps to keep it on!
