crazybrownklick
Removed spark plugs and on cylinder 3 I notice it had coolant on it haven't removed the rear one but I'm assuming that they will have coolant too will thus be case with the head gasket or the lower intake gasket
This is commonly a gasket in the intake tract. Meaning this can be a throttle body gasket, a supercharger to LIM gasket or a LIM gasket. Likely though..I'd put high odds on the first two.
And if you have a TB spacer...well we know right where the leak is.
I may have a similar problem. White smoke had come from my passenger side. I had it towed. I was told that I needed to replace my water pump, radiator, thermostat, and hoses. I replaced all of them and when I went to flush the system, I detected leaking. It wasn't too apparent where it was leaking from. A puddle formed just underneath the oil pan. When I went to drain the water, I could hear a hissing sound coming from just above the water pump but below the supercharger. Any thoughts?
