Coolant leak Please help
KwazrollinZ28GTP
Im losing my mind, i have an L67 About to buy a l32 or sell the car if i cant fix this.
I have a coolant leak (light smoke out of the exhaust) i keep getting coolant inside of the Intake manifold, and then its burning in the chamber.
I have Done so far, replaced the head gaskets, ZZP aluminum intake gaskets, Blocked the Supercharger coolant ports AND tried a SECOND intake manifold.
That's Typically the only thing that Stops a coolant leak Right????
Is it possible i have a cracked block or Head? And how the hell could that happen????
Also there is NO coolant in my oil just in the intake. :th_depressed:
I bought that reusable gasket with the yellow o rings and havnt had a problem with it and i just had to replace my m90 today?
No Im saying take the blower off and look into the intake and pressureize the coolant system and see where its leaking from. Just make sure the coolant passages are blocked off good to the TB.
Have you checked for a blown head gasket? Check cylinder compression on each cylinder.
Brand new felpro headgaskets/ bolts, zzp aluminum intake gaskets, And blocked off supercharger Coolant ports.
Right i got what you meant, but im tired and said the wrong thing lol
Whats the best place to blow air through?
