upmichigan
Hi
I am working on my son's 07 GP standard 3.8. We have been through the bypass elbow failure and replaced them with aluminum about 2yrs ago. A few months ago, he started losing a little coolant and I purchased a water pump and another set of elbows just in case. The small leak just became a huge leak and I replaced the pump and elbows again. This did not help.
The leak is continuous down the passenger side of the motor (w/o car running - I should have looked closer before starting the replacement of the pump and elbows...). If you are looking at the water pump, it starts in the area behind the part of the casting that the water pump bolts to, behind the area that the radiator hose connects to. If I stuff a rag in this area from the bottom, it becomes saturated. If I stuff a rag in the cavity below the intake manifold (below the bypass elbow), but above the water pump, it stays dry. I'm assuming this means no leaks from lower manifold or elbow.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
