raythecaddie
I have a 2006 grand prix and it seems that I have a coolant leak in behind the water pump, how can that be and what part is behind the water pump
Thanks for the reply, does the water pump bolt directly onto the block or is there a part between the pump and the block. The pump was recently changed by a mechanic and he said the part behind the water pump is also leaking and he would fix it for $700, but I called bs on that. I always thought the pump bolts directly to the block.
