Sure
In 95 when the Series II motor came out the lower elbow was cast as a part of the alt/tensioner assembly bracket. This means that only the top elbow was plastic. GM made a change to the W bodies starting in 99 and the rest of the bodies in 00. The change was to make both elbows plastic. No manufacturer makes a change like that unless there is a good reason.
If you read enough, you'll find posts where I tell guys to wiggle the hell out of that older style with the cast lower elbow to the radiator and firewall only. If you put much pressure on it toward the passenger strut, you may have a lower elbow leak when you put it back together. Except, it's not a lower elbow leak, you cracked the timing cover. Where the elbow goes into the cover, it's thin and weak. The plastic elbows have flex to a degree. Then there's corrosion over time. Plastic doesn't corrode a whole lot. :th_winking:
Next up, you guys think the elbows leak based on what?
1. O-ring? Plastic and metal use the same o-rings. I don't buy an o-ring as the issue. Clean the damn holes and lube the rings.
2. Elbow deforms? If your upper elbow is deforming, then there is pressure on it when it's being tightened or your cooling system is building more than 16psi that the cap is rated. Wiggle the elbow as you are tightening the bolts. The elbow shouldn't be immobile when you tighten things. If it is..then something is binding it, once heated it will likely deform.
These are the typical things I see blamed for why they leak. A year or so back Dorman published that they had trouble with a run of the elbows and said, they'd replace them for free. So there was a bad batch of them out there. It's not as widespread as the issues though. I know I'm not a genius or the worlds luckiest guy, yet I never have elbow issues....at least since I realized why mine became a 45 degree angle instead of a 90. I had pressure on it. I do a lot of these elbows and to date, two have leaked or had an issue, out of say 100+. One could say I didn't put those couple in properly, especially since I know I did on one of those.
